MH 44 again
Shane
05-25-2002 06:10:25
Thanks for the info, but have a new problem. I got it put back together and she fired right up and purred like a kitten, but when I let out on the clutch the tires just moved about 6" and it made a grinding noise. It had done this before and I replaced the clutch, pressure and fly wheel. That didn't fix it. It sounds like it it coming from the rear end or transmission. What do you think?
Bruce Colbourne
05-27-2002 18:08:25
 Re: MH 44 again in reply to Shane, 05-25-2002 06:10:25
Shane-In regaurds to the grinding noise.Take the covers off the trans and rearend.Check the shifter forks to see if one is bent or loose check the bearings on the shafts.It could be possible a bearing is starting to fail.The massey 30 we had on the farm had a loose shifter fork and it wasn't putting the gear all the way into position and it would sometimes grind and kick out of gear.Hope this helps you.Bruce C
