Help with MF 1020 electrical problem
Mike Laughlin
05-23-2002 06:21:24
I have a MF 1020 diesel. When I turn the ignition to glow nothing happens. I live about 40 miles from the nearest service facility and would like to try to fix the tractor myself. The battery is good and there is power to the ignition and starter. Can anyone give me some suggestions on where to start? I'm not a mechanic, but I can use and read a multimeter. Thanks
Peltsi
05-23-2002 23:41:43
 Re: Help with MF 1020 electrical problem in reply to Mike Laughlin, 05-23-2002 06:21:24
At least on my mf168 electricity is used only to light the fuel coming to the glowplug, so it's acting like a blowtorch. You could check if there is any fuel coming to the plug. Also, check with that multimeter that there is really 12 volts going to the wire which goes to the glow plug. If not, your ignition switch has propably gone bad...
If the problem is neither of these, then the problem propably is with the glowplug itself
Hope this helps.
