MF 35 transmission stuck in gear
Lem
05-16-2002 12:52:51
Ferguson 35 is stuck in gear.Can I get to shift forks through side,or go through top? I think I can push in clutch and then move forks.
GREG
05-17-2002 19:55:41
 Re: MF 35 transmission stuck in gear in reply to Lem, 05-16-2002 12:52:51
ON THCLUTCH SIDE OF THE TRACTOR THIER IS A OPENING YOU CAN USE A PIPE WRENCH OPEN IT AND USING A10 INCH BAR YOU CANWORK IT OUT. I'VE DONE THIS A FEW TIMES IT IS CAUSE BY SPEED SHIFTING INTO ANOTHER GEAR.
Gordon-(TN)
05-16-2002 23:04:43
I get mine to go back right by pulling up on the gearshift and working it around till it goes back in place. hope this helps Gordon-(TN)
Henning Thomssen
05-17-2002 09:06:02
 Re: Re: MF 35 transmission stuck in gear in reply to Gordon-(TN), 05-16-2002 23:04:43
That's how they lock up in the first place,pulling up on the lever while shifting.I locked my 50 up once,now i make sure i don't pull up on the lever,no problems in 10 years!
H.T.Hertz
05-16-2002 12:58:32
Go in thru filler cap next to gear lever, and snap back shifting fork with a screwdriver.
More info on Big Dean's Website
Henning
