FE-35
Steve
05-15-2002 22:34:40
I have a gas FE-35 and the airfillter has thick black oil in it. Does the fe need that type off fillter.If it dose what type off oil do i use and how muchdo i put in.
H.T.Hertz
05-16-2002 00:12:44
 Re: FE-35 in reply to Steve, 05-15-2002 22:34:40
It is a fine filter when used correctly.
Wash the bowl and mesh in gasoline, let dry, then fill bowl to the indicator line and refit.
Normally you can see from the amount of dirt in the bowl when to clean and change oil.
The oil to use is standard engine oil, the same as you use in the crankcase.
Henning
Taageskov
Denmark
