44d seat shock absorber
steve oliver
05-14-2002 06:43:00
Does anyone know if new seat shock absorbers are available for an early 50s Massey Harris 44D?
JASON TN
05-23-2002 18:42:55
 Re: 44d seat shock absorber in reply to steve oliver, 05-14-2002 06:43:00
I USED A SHOCK THAT GOES BETWEEN THE CAB AND FRAME FOR MACK TRUCKS. I HAD TO TRIM THE RUBBER BUSHING SO IT WOULD FIT ON ONE END.
Michael
05-14-2002 15:56:32
Monroe had a part number a few years back, but
often this is not the solution. The "Velvet Ride"
seat had a choice of three conical springs. If your weight is 160 lbs, with the HD spring, you
ride a lumber wagon. I believe Seymour Spring,of
Ohio(?), supplied the M-H spring. To avoid the problem of breakage, most orders included the
heavy spring for the big guys to compress. I
recall an actual "velvet ride" on a 44 with the lighter spring, good shock, and my 162 lbs. I
wish I had that conical spring today. Perhaps it
can be matched, after market. More lost parts
details. Good luck to all the M-H searchers.
