Wimpy Stabilizer Arms on MF150
Jon D
05-12-2002 17:54:44
I pull a 6' Woods heavy duty brush hog with my MF150 and I am having a terrible time with the stabilizer arms. This mower weighs about 900 pounds and the stabilizer arms look like pretzels after a few sways of the mower. Are there some heavy duty arms that will handle this or should I consider adjustable arms (they seem a little more stout than the 1/4" flat stock bars I have now)? Thanks for the input!
chris mf35
05-16-2002 19:01:45
 Re: Wimpy Stabilizer Arms on MF150 in reply to Jon D, 05-12-2002 17:54:44
mine has chains for sway control (homemade by someone before me) however tsc stocks the. one on each side both adjustable. does not cause binding like two swaybars. plus can be left real loose when plowing to reduse sway when plow is in air.
Ray(MD)
05-15-2002 11:23:06
Jon,
I also have a MF150 and pull a 6 foot hog. I put on adjustable stablizer arms on both sides. Just like Boss Hog stated here and have not had a problem for many years.
DH
05-14-2002 12:43:33
I had the same problem with the flat bars. I backed off each end 3 inches or so and then laid a piece of 1 1/4 inch angle on the bar and welded it solid. It sure added some much needed stiffness.
DH
05-14-2002 12:43:26
Jerry (AL)
05-13-2002 11:08:45
I went with the round stabilizers for the same reason. Easy to bend the flat one.
Boss Hog
05-13-2002 10:44:17
Try putting a stabilizer bar on each side. That way, one of them is always in tension.
