Massey-harris ID needed?
rob Lak
05-11-2002 18:36:49
Hi all. My sister is buying a small farm (2 acres) and it comes with everything in the barn. Inside is a massey-harris tractor (i thought i read "pony" on the front end, but i can't be sure.).
I looked for a model number but didn't have time to look closely. I did find a metal plate on the right side of the engine(?) that says N62 31947. No other writing was available there. Is this the model or serial no? Can someone send me a link to this specific model? THANKS!
Bruce Colbourne
05-11-2002 22:08:51
 Re: Massey-harris ID needed? in reply to rob Lak, 05-11-2002 18:36:49
Hi Rob-The massey pony used a continental four cylinder engine.It was a 62-cubic in engine.The number you posted is the engine serial number.The tractor should have a tag on the chassis with the serial number on it.If tag is missing see if there are any numbers stamped anywhere on the chassis.Massey usually stamped the serial number on the chassis also.I am not sure where it would be on the pony.Bruce Colbourne
