MF135, AD-152 torque settings?
Jack M, UK
05-11-2002 12:03:49
Could someone tell me what the torque settings are for for the big ends?
Do the bolts on the timing gear case, inside (holding the case to the engine) and outside have a particular torque setting?
If someone has a list of all the torques on the engine that would be BRILLIANT!
Thanks alot, this is pretty urgent....
Jack M, UK
Jack in NB
05-12-2002 04:15:02
 Re: MF135, AD-152 torque settings? in reply to Jack M, UK, 05-11-2002 12:03:49
Sorry - I missed some!
We use the same tourques as the ones listed for the various unlisted bolt sizes. 1/4" = 6-9 lb/ft, 5/16 = 19-21.
Seems to work. We assist with silicone caulking on all the gasket surfaces except the head gasket. It calls for a non-hardening gasket sealer, and tightening in the spiral pattern from the centre out in 10 to 15 lb increments.
The 77 DSB cautions about head bolt lengths - if they are too long, they can score the camshaft.
Jack M, UK
05-12-2002 03:01:14
By the way, it is an AD3-152. Dunno if the 3 matters?
Jack in NB
05-12-2002 04:04:52
 Re: Re: MF135, AD-152 torque settings? in reply to Jack M, UK, 05-12-2002 03:01:14
Hi -
AD3 152 tourques from 235 MF shop manual:
Con rods 40-45 ft/lbs
(From Vapormatic: Cadmium [silver] nuts 45 lb/ft Phosphated [dull black] 60 lb/ft self locking nuts 70 lb/ft)
Cyl head 60 ft/lbs (dealer serv bulletin 77-47)
Mains 110-115 ft/lbs
Balance weights 50-55
Crank pulley 100-110
flywheel 74-80
idler gear hub 45-50
injection pump gear, camshaft gear, oil pan 19-21
rocker shaft supports 21-24
intake manifold 6 - 9
exh man 12-15
injector hold-down nuts 10-12
injector nozzle cap nut 50
Jack M, UK
05-12-2002 07:12:09
 Re: Re: Re: MF135, AD-152 torque settings? in reply to Jack in NB, 05-12-2002 04:04:52
Where did you get this information from, a book?
If it was from a book, would you be able to tell me the name of it as I am going to be working with the engine for sometime still.
Thanks
Jack
Jack M, UK
05-12-2002 06:59:10
Thanks alot for the list of torques, they will help me to assemble the engine that is in bits now.
Once I have assembled the tractor together, I'll then see whether it will start..... .Wish me luck!
Regards
Jack
