MASSEY FERGISON 50H
JODY HANSON
05-09-2002 17:48:37
can anyone tell me how to remove the gland nut on the jack leg cylinder there is a hole on the bottom side of the cylinder just below the gland nut and you can see a snap ring but the nut won't come out it just spins there must be a trick to get it out any help would be great.
Bryan
06-03-2002 10:35:00
 Re: MASSEY FERGISON 50H in reply to JODY HANSON, 05-09-2002 17:48:37
If your cylinders are like mine (50A industrial backhoe 1971) there is a small hole in the cylinder behind the nut. You have to take a pair of needle nose pliers and pull the cable out that holds the end of the cylinder. All you can really see from the outside is a small hole. Also I found out that atleast some of the cylinders on mine are metric.
