Pony hand crank starting
Woodcutter
05-08-2002 17:12:19
Wondering, does anyone regularly start their Pony using a hand crank? My ring gear is worn out and thought I could start it by hand if I could locate the tool.
Ken in Iowa
05-11-2002 07:32:21
 Re: Pony hand crank starting in reply to Woodcutter, 05-08-2002 17:12:19
Woodcutter: Mine was worn also. I removed the flywheel and just had the old ring gear fliped over. When warmed up with a torch it will slip right off. It works fine. I think new rings are available too. Good Luck, Ken
rhudson
05-09-2002 17:15:50
Hi Woodcutter,
i crank mine all the time with crank (my generator does not work). the crank is tapered with a cross drilled pin on the engine end. if you cannot find one, i could measure mine. a machine shop should be able to make one in less that an hour.
Jeff
05-14-2002 13:07:22
 Re: Re: Pony hand crank starting in reply to rhudson, 05-09-2002 17:15:50
Hey,
I'd be interested in the dimesions as well I'd like to get a hand crank for my '51 Pony.
