Massey Harris/Ferguson 50 3 point hitch Trouble
TT
05-07-2002 09:04:44
I need to find a online manual in regards to the 3 point hitch for the massey 50. It wont lift up
could anyone email me with some way to resolve this or a breakdown of the 3 point hitch so that I may fix the problem
bob
05-07-2002 20:03:58
 Re: Massey Harris/Ferguson 50 3 point hitch Trouble in reply to TT, 05-07-2002 09:04:44
You dont have a 3-pt. hitch problem;technically a hydrualics problem, probably a pump failure (O rings) but maybe a valve. On the right side-as you sit on the tractor-below the hydraulic lever, is a round disk bolted to the side of the housing (6 bolts I think). Inside is a valve, short & silver-colored. Use an open-ended wrench & unscrew & replace valve. Unless your problem is low fluid.
