Help on MH Model 72 Combine
Woody
02-12-1999 13:27:24
Trying to determine the motor that's in this unit. The owner says it is a Chrysler. I've seen it by trouble light...good sized six cylinder flat head motor. Would this (or could this) be a Chrysler? Or more likely a Continental?
BOB
01-15-2000 11:07:55
 MASSEY HARRIS 101 SR. in reply to
Tom from Ontario
02-14-1999 19:13:18
 Re: Help on MH Model 72 Combine in reply to Woody, 02-12-1999 13:27:24
Woody: Chrysler 230 flathead. Industrial version of the same engine that was in the original Dodge power wagon 3/4 ton truck. Keep the dust off them, they burn real good. Good Luck. Tom
Craig
01-10-2000 06:17:54
 Re: Re: MF-245 Engine Noise in reply to Ernie D, 01-07-2000 17:03:25
Supposedely tach's are accurate on both. If I understand piston slap correctly, wouldn't it do the same thing under full load?
Oil pressure is fine on both according to dash gage. It's not possible to dyno test. Cold weather starting is fine on both, in fact both came from Canada. Oil seems thick on the one that doesn't have the noise I'm refering to.
What does the Amsoil test kit check for?
Thanks for your response.
