MF 65 Spin-out rear wheel
Tom
05-06-2002 19:12:29
I was trying to adjust the rear spin out wheels and cannot get several of the locks loose. I have oiled and let set with no luck. Does anyone have any advice? Use a torch and heat?
Thanks,
Tom
Chuck
05-10-2002 13:08:09
 Re: MF 65 Spin-out rear wheel in reply to Tom, 05-06-2002 19:12:29
I replaced the tires on my 'ol 65 and unbolted the entire casting, soaked them in diesel for a day or so and was able to get them moving again. I had to replace the rims as the tires were loaded for years. Dang that salt but sure miss the weight!
Tom
05-08-2002 07:53:24
One wheel's lugs came loose fairly easily but the other has not budged. I thought I would probably have to use a torch. Thanks for the info.
bob
05-06-2002 22:49:16
what worked for me was to leave the tires on and use wood blocks to fill up the wheel well til a hydrualic jack on top of blocks touches rim at top, then jack slightly til the bolt turns. Mine busted several snap-on 1/2 inch square sockets til I wised up. The bind is because of the rim being bent from years in service and pressure holds the bolts. Jacking it (easy does it) relieves this pressure & mine turned easily then. Jack a little, try the bolt; jack a little more, try to turn bolt again til it works. Breaker bar is better than a rachet.
TAB
05-07-2002 19:57:19
 Re: Re: MF 65 Spin-out rear wheel in reply to bob, 05-06-2002 22:49:16
If you have not read my note on 5/06/02, please do so.
My lugs must have been in far worse shape than Bob's. Even after taking them off and putting them in a vice, I could not turn them. Like I said, I had to heat mine cherry red to get them to turn..... but there was a lot of rust and crud built up inside them.
If mine had not been in such bad shape, I believe Bob's idea might have worked.
TAB
05-06-2002 22:29:16
I replaced the rear tires on my 1964 MF65 (38" tires) with spinout rear wheels last fall. I think the tires were the original tires and I don't think the spinout lugs had been loosened in decades. I couldn't get them to budge, even with an impact wrench. I had to take the spinout lugs off and heat them with an oxy/accet. torch to cherry red to get them to budge. It was somewhat of an undertaking, but I got all the lugs to work...lots of rust built up in them. Don't know if that helps, but that is what I had to do. Good luck!
