Massey-Harris 20
redrev
05-06-2002 17:40:17
Where can I buy a head gasket for a MH 20? Any idea of the cost? Which Continental engine is in this tractor? I can't read the plate. Thanks
Bruce Colbourne
05-06-2002 20:00:28
 Re: Massey-Harris 20 in reply to redrev, 05-06-2002 17:40:17
The mh#20's that were built from 1946 to 1948 used a four cylinder continental engine.The gasoline version was 124 cubic-in's;the low-grade fuel was 140 cubic-in's.If you look on the lefthand side above the oil filler cap the engine size is stamped in the block.Check the parts site on the left side of the screen they have agood selection of parts.If you know some one who has a older linkcon welder they used the four cylinder engine and they could tell you where the get there engine parts.The 124 and 140 and 162 are all the same block they just changed the bore of the engine.The stroke is the same. Bruce Colbourne.
justin
05-07-2002 08:58:38
 Re: Re: Massey-Harris 20 in reply to Bruce Colbourne, 05-06-2002 20:00:28
Could you tell me if the heads where the same on those engines too? thanxs
Bruce Colbourne
05-07-2002 14:36:07
 Re: Re: Re: Massey-Harris 20 in reply to justin, 05-07-2002 08:58:38
The heads are the same on these engines. Bruce Colbourne
redrev
05-06-2002 23:33:30
Thank you very much Bruce. I wouldn't know where to begin without this board. Sure glad I found it, and sure glad you are all so helpful. G
Frank Aldous
05-07-2002 10:48:02
 Re: Re: Re: Massey-Harris 20 in reply to redrev, 05-06-2002 23:33:30
The napa auto parts stores have parts for these engines. I have a massy harris 30 and I got a head gasket and intake theie. My massy harris is a 1948 1949 i have two.
