FE35 Front wheel alignment
Craig in NZ
05-06-2002 15:03:26
Hi team,
The front wheels on my FE35 are not aligned properly. When one is pointing straight ahead the other one is pointing slightly in towards the straight ahead one - as if starting to turn a corner!. This is making it difficult when making turns and also the slightly off wheel seems to rip up the paddock a bit on that side - I guess because its started a turn but is being pushed straight ahead!. It seems to me there is some adjustment in the long shafts which run to the steering arms but Im not too sure. Can someone advise or correct me if Im wrong please. Thanks.
Roger
05-07-2002 06:55:27
 Re: FE35 Front wheel alignment in reply to Craig in NZ, 05-06-2002 15:03:26
Craig;
You are correct- the wheels should point in the
same direction. Get the steering wheel centered
and loosen the nuts at each end of the steering
link rods. Rotate the rods to lengthen or shorten
the link as necessary to get the wheels parallel
AND pointing straight forward by means of
measuring between the center ribs of the tires (at
hub height) at both front and rear of the wheels. My TO-35 manual calls for toe-in of 0 to 1/4".
It's not hard to do- just take the time to measure
accurately.
Good luck,
Roger
Craig in NZ
05-07-2002 18:49:13
 Re: Re: FE35 Front wheel alignment in reply to Roger, 05-07-2002 06:55:27
Excellent - thanks for that Roger!
