MF50 fender mounted toolbox
Jeff in TN
05-05-2002 13:14:45
I have a MF-50 with a toolbox in the fender. The bottom has rusted out. Are replacement toolboxes available anywhere?
Thanks..
Big Bob
05-06-2002 13:20:30
 Re: MF50 fender mounted toolbox in reply to Jeff in TN, 05-05-2002 13:14:45
I used a piece of tin that I pop riveted onto the bottom of my rusted out wheel toolbox. I left the ends with just a enough of a gap so that the air can move the moisture out. I then painted it and the fender. Looking at it you can see it is homemade but it is perfectly functional and maybe better than the original design. Unless you are looking to restore perfectly, this is a simple repair option.
David B
05-05-2002 16:49:27
I cut the bottom of the tool box off and formed a bottom out of expanded metal this lets the dirt fall thru. The dirt collects moisture which causes the rusts which eats the bottom out. I don't know if you can still buy the tool box or not.
