Massey 202/ 35 lift pin leaks, spins, how to fix
greg m
05-04-2002 21:09:52
I have a massey 202 which isalmost the same as 35. the problem is that the lift pin which holds the lift arm at the axial leaks. I cannot get the bolt of because it also spins.
What would it take to fix this, can I get to it from the top cover?
Bob in CA
05-04-2002 21:20:41
 Re: massey 202/ 35 lift pin leaks, spins, how to fix in reply to greg m, 05-04-2002 21:09:52
I believe that the only way to fix your problem is to remove the axle housing. I did this recently for this very reason. The pin has an o-ring on it to seal it. On my tractor just tightening from the inside was enough to seal it. I removed the axle first then the axle housing otherwise you can stress the axel seals and ruin them. If you have any leakage into the brake area, this is a good time to seal this as well. The job took me about three hours.
Bob
