Ring gears for 44
Mark
04-29-2002 15:45:21
I am looking for a new ring gear for a Massey Harris 44. Where can I buy one or who has one? The one thats on there wont let the starter engage properly, and it appears to be turned already with bad spots on the other side. Thanks in advance. It is a four cylinder.
Mark
bob
05-11-2002 09:44:19
 Re: ring gears for 44 in reply to Mark, 04-29-2002 15:45:21
Mark didn,t se thispost when was current but i have a 4 sp. and a 444 . late works good. but put rbuilt starter on sp and it don,t engafe rght either got a diiferent ring gear but same proablem think maybe there is 2 diferent gears seems like one I bought had 131 teeth one of thse days will count both of them mine is just schrunk on but one i bouught was to small if find out right inf will post in new post bob
matt
05-02-2002 17:09:41
i have the same problem this weekend I am going to take it apart and try to cut the welding and turn the gear around, I think it is a common problem I have a 44 and 44special both do it. thanks matt I will let you know if it works.
Mark
05-02-2002 20:18:14
 Re: Re: ring gears for 44 in reply to matt, 05-02-2002 17:09:41
Mine is not welded, I took a punch and hammer and tapped around it, and it came loose. Think I found someone who can get me a new one. Hope so, or else gotta go to a scrap yard and take on out. What did mine in was the starter i had rebuilt, the people who did it put in the wrong spring, and I put it to twelve volts, didnt take long before it was shot. Good uck
Mark
Gary (ont)
05-01-2002 06:03:43
Mark, you could try Mr. R. Corbin in Silex Mo. Ph. #573-384-5939. He was parting out a 33? or 44? during the winter. Good honest man to deal with. Gary
