Help re 135 MF diesel starter/solinoid wire hook up
Tom Walker
03-14-1998 15:23:01
have a 67 Massey Ferguson 135 diesel which recently needed some cable/wire and connectors replaced. I made a diagram of how things were before I started. I lost that diagram...drawn on back a match book cover... I know I know... I'm a putz for loosing it. Anyway my question is really about the samller gauge wires ... I have a brown wire and a red wire and a white wire... These can only go on either of the small terminals on the Solinoid cap and then theres the brown wire which I think may go on the big terminal...which also has two other wires there now.... anybody got a wire diagram of this unit they can down load... Its worth a coffee and donuts next time your in Bragg Creek, Alberta, Canada.
Thanks in advance to anyone with the time to help with this minor delima... The dealers can proably help with this and I'll eventually get over there to them if this don't work>
Jigu
03-21-1998 07:01:38
 Re: help re 135 MF diesel starter/solinoid wire hook up in reply to Tom Walker, 03-14-1998 15:23:01
No Comments
Fireball Melton
03-16-1998 18:39:58
Hi Maybe I can help! Is the brown wire biger than the other two? If it is ir gose on the post with the battery cable, the other two , Check the wires coming out of the safty switch the color if these wire will be the same as one of the two lift that one gose on the inside post. The other one should go on the outside post. Are puting on a new wiring harness? Also has it got a alt.
