F40 and a Log Splitter
John Thornton
04-22-2002 10:50:37
I am looking at a log splitter to go on my MF F40. I have a valve under the seat that goes to a two way valve mounted on the fender. The valve under the seat when it is pointing up the three point hitch works and when it is pointing left or right I assume hyd fluid is sent to the hoses that go to the two way valve. Now the log splitter company wants to know if I have a "Open Center System". Danged if I know.... Can anyone help here?
Larry Counts
09-05-2002 13:00:54
 Re: F40 and a Log Splitter in reply to John Thornton, 04-22-2002 10:50:37
Hi
It should work, I just installed a Tractor supply 3 point log splitter on my newely aquired FE35. It works fine, although it is a little on the slow side. The tractor has 3/8 inch output & the splitter has 3/4 input. If there is any other help I can offer, feel free to email me.
dan
10-24-2002 12:12:40
 Re: Re: F40 and a Log Splitter in reply to Larry Counts, 09-05-2002 13:00:54
I HAE TRIED TO MAKE A THREE POINT SPLITTER FOR MY
35.I TESTED THE PUMP PRESSURE IT IS 2200 PSI.I BYE PASSED THE TWO WAY VALVE AND WENT STRAIGHT TO THE RAM IT STILL DOSENT HAVE MUCH POWER HAVE YOU ANY IDEAS.
