Which Way Does the Spring Go?
Dan
04-20-2002 17:04:36
My MF135 gas has the old style canister oil filter with internal replaceable element (not spin-on type. Does the spring go next to the block, or at the top of the canister? Does the flat washer on the spring go toward the element or away from it? I've looked thru my operator's manual and the I&T Service manual- can't find any diagram or notation of this anywhere. I assume the spring would allow the oil to bypass if the filter was too clogged? Any help here would be appreciated.
Keith G.
04-23-2002 00:39:17
 Re: Which Way Does the Spring Go? in reply to Dan, 04-20-2002 17:04:36
Spring at bottom of canister then washer, this pushes element against block, if it gets restricted the element pushes away from block and " bypasses".
Thanks Guys- I Appreciate Your Help! Dan
04-22-2002 17:30:28
Thanks for your comments. And thank you H.T. for the link to the diagram- as they say, a picture is worth a 1000 words...
H.T.Hertz
04-22-2002 12:50:16
This link shows more than many words tell:
Link
Don't be scared by the swedish names, a drawing doesn't know any languages.
H.T.Hertz
Denmark
rick news
04-20-2002 20:48:09
the #1 block #2 filter #3washer #4 bolt
in that order is the way I have seen them
thebigron
04-22-2002 03:53:10
 Re: Re: Which Way Does the Spring Go? in reply to rick news, 04-20-2002 20:48:09
SEEMS LIKE A GOOD TIME TO INVEST 25 DOLLARS FOR THE SPINON KIT.
