PROBELMS WITH 65 MASSY FERGUSON
Marty
04-18-2002 21:51:46
HELLO,...I HAVE A 65 MASSY FERGUSON..THAT I AM HAVING PROBLEMS WITH. IT STARTES GREAT, BUT ONLY WANTS TO RUN WITH THE CHOKE ALL THE WAY OUT..AND NOT GOOD THEN. I HAVE PUT ON A NEW SEDIMENT BOWL AND CLEANED THE FUEL LINE....ANY IDEAS....?
smokey
04-20-2002 16:40:33
 Re: PROBELMS WITH 65 MASSY FERGUSON in reply to Marty, 04-18-2002 21:51:46
Have you checked the filter on the tap in the fuel tank - need to remove tap etc and the mesh filter above the fuel bowl near the fuel pump, I have a diesel and I think the petrol models may be the same.
Tim(nj)
04-26-2002 18:21:15
 Re: Re: PROBELMS WITH 65 MASSY FERGUSON in reply to smokey, 04-20-2002 16:40:33
65 gas with G176 Continental is gravity feed. No fuel pump. No filter except for sediment bowl mesh. The carb originally had a mesh in the inlet elbow, too. Our 65 had the same problem. Ended up putting a new carb on to solve it because no matter what we did to that old carb, just couldn't get it to work. Must've been a crack in it somewhere.
lc
04-19-2002 08:58:33
First guess is that the main jet is plugged or there's a good sized vacumm leak somewhere.
