Oil Pressure of 101 super senior
Color Blind
04-18-2002 18:32:18
Does anyone know the proper warm engine oil pressure of a Chrysler Powered 101 Senior??
I've got 42 cold and 22 hot.
Allan
04-20-2002 21:26:51
 Re: Oil Pressure of 101 super senior in reply to Color Blind, 04-18-2002 18:32:18
On a good Chrysler you should have 40 lbs at rated speed, hot or cold, but I 've seen much worse than yours still running good. A set of rod shells might be all you need to make it right.
Alberta Mike
04-19-2002 05:47:17
Don't have any tractor specs but I do have a factory manual for 39-40 1/2 ton trucks. This says that at 30 mph, the oil pressure should be 30-45 pounds with 15 pounds at idle. That would be pretty much the same engine I would think but for a brand new engine. I had a '51 Dodge pickup a few years back and your pressure sounds about like what I was getting, and that old truck was a pretty strong old beast. I'd say you're OK.
