Do I really have a MF35X?
Tom Nordahl
04-13-2002 02:21:21
According to the plate below the instrument panel, I have a 35x SNMY355451, but is it possible that I have a MF35 with a 35x bonnet(hood)?
I do not have MultiPower.
I have :
Dual clutch
Diff lock
Perkins 3 cyl diesel (but is it 44 hp?)
I guess the fundamental question is:
Are all MF35X fitted with Multi Power?
Tom
C. T. in Oklahoma
04-13-2002 14:02:09
 Re: Do I really have a MF35X? in reply to Tom Nordahl, 04-13-2002 02:21:21
I couldn't respond about the multi-power, mine does not have it. I was told that "X" meant dual clutch, differential lock, tractormeter (a meter that measures hours and mph/kph) and I believe hi-low range.
young restorer
04-13-2002 14:25:48
 Re: Re: Do I really have a MF35X? in reply to C. T. in Oklahoma, 04-13-2002 14:02:09
It is difficult to distinguish a 35X from an ordinary 35 as some ordinary 35's were fitted with diff locks and there were not so many 35X's fitted with multipower.The only real way of telling is to know the exact model of perkins engine it carrries. For example if it has a P3 then it is an ordinary 35. A 35X should have something like an F3.152 or AD3.152. I hope this is of some help.
smokey
04-13-2002 16:22:23
 Re: Re: Re: Do I really have a MF35X? in reply to young restorer, 04-13-2002 14:25:48
The way to tell a A3.152 from a direct injection AD3.152 is by the head and injectors. A3.152 injectors are bolted at 90 degrees whilst AD3,152 injectors are at a slight angle ie 80 degrees.
Tom Nordahl
04-14-2002 11:58:03
 Re: Re: Re: Re: Do I really have a MF35X? in reply to smokey, 04-13-2002 16:22:23
Thanks guys.
Wonder what I would do with out the people in this forum!
Peter Tatham
04-13-2002 12:57:30
Yes, you do. The 35X was made either with or without multi-power.
Tom Nordahl
04-13-2002 13:49:26
 Re: Re: Do I really have a MF35X? in reply to Peter Tatham, 04-13-2002 12:57:30
Thanks Peter. Bits and pieces falling into place. For the moment, my understanding is that the difference between the 35 and the 35x is horsepower and diff. blocking.
Anyway, it really doesn't matter. I'm glad I bought the old girl and looking forward to restoring her.
Tom
