Still leaking
Dave
04-12-2002 05:25:54
I just replaced the rear crank seal on my MF 135, its the 3cyl. perkins gas engine. I am quite sure I installed it correctly,I took my time and followed the manual as I did not want to split the tractor twice. Got it back together and it leaks as much as it did before. Any ideas?
Thanks, Dav
joseph keenan
04-17-2002 03:08:01
 Re: still leaking in reply to Dave, 04-12-2002 05:25:54
The seal may be installed right but the surface of the crank may be bad. Did you have a groove or
pitting in the crank surfaceA? It can kill a seal
in minutes. The fix is resurfacing this area.
I just went through this same thing. The pan could
be leaking and is a "easy" thing to try first.
There are some seal companies who make a sleve to on the worn surface instead of machining, this means no pulling of the crank.
Floyd
04-12-2002 14:59:17
The seal houseing has been known to crack
Big Dean
04-12-2002 08:05:31
What you think is a rear crankshaft seal leaking on the AG3-152 gas engine or the AD3-152 diesel is usually the rear pan gasket it is about a 1/4 inch square cork gasket about 10'' long on the ones with the rope seal about 12'' on the ones with the big rubber seal. These gaskets get hard & dry from the heat of the engine & usually start to leak about every 5 to 10 years according to how hard you use the tractor. Email me if you have any question about this
Thyge
04-12-2002 08:00:01
Did you check that the crankcase breather line from the valve cover is not plugged, otherwise motor oil may be blown out thru a perfectly ok seal.
Thyge
Orlando: Volant, PA
04-12-2002 06:34:39
Dave: Best bet: Check with Big Dean Austin. He will probably know. Good Luck
