Missing serial number plates
GW
04-08-2002 03:36:13
I just bought 2 Massey Harris 44's--one is a
tricycle, the other is a wide front. The wide
front is stuck (cylinder 4). The tricycle runs great!! Where can I find the serial numbers
stamped on the tractors? I have tried most of the places everyone says to check. Haven't uncovered any numbers yet.
Tom W.
04-08-2002 13:33:38
 Re: Missing serial number plates in reply to GW, 04-08-2002 03:36:13
The numbers are stamped on top of the transmission behind the PTO on/off lever. They will read 44GR and then your serial number. People do Repo the serial tags.
GW
04-08-2002 16:36:44
 Re: Re: Missing serial number plates in reply to Tom W., 04-08-2002 13:33:38
Thank-you and the help everyone else has given.
The serial numbers were hiding under a plate with
a lock out handle and 2 bolts preventing the PTO
from being engaged. After taking the plate off
the numbers were easy to find and read. They are
as follows: wide front-44GR #12779 tricycle---44GR #10710 If I am reading the serial number charts right,
that would make them both '49 models. Thanks again.
