Mh44 or 44sp
ennismore mike
04-07-2002 17:37:03
I have a Massey Harris 44 or 44SP. The serial # is 44G1SF 45316. The 44G1SF suggests that the tractor is a 44 Special, however the 45316 suggests it is a 44. Any ideas which it is ??
David B
04-08-2002 17:30:14
 Re: mh44 or 44sp in reply to ennismore mike, 04-07-2002 17:37:03
By the number its a 1953 44. The 44G1SF in the model number is G-gas,1 is for reg altidude compression, S-standard, F-foot clutch. Any number under 47060 would be a 44.
matt
04-08-2002 12:01:57
I have a 44special and It also did have id plate, but an older man told me that if you look by the pto lever it should also be placed there in larger letters. This is how I id my tractor. hope you find it matt
Michael
04-08-2002 10:43:31
Unless you have a combo of assembled parts, your
44 is a 40K series, 44 Standard, made in the
final year, 1953. The 40k series debuted in mid
1952, with throttle back on the steering column,
dual color rear light,thicker cast pedestal. All
44 Specials have 50K serial numbers. The quickest way to know it's a Special, is the shift boot
has a steel engage bracket bolted over it, same
as the Triples have.
GW
04-08-2002 03:23:18
I just bought 2 MH-44's--One is a wide front and the other is a tricycle. The wide front is stuck
and the tricycle runs great. The serial number plates are gone on both tractors. Where can I find the serial numbers stamped on the tractors?
I really like both tractors and plan on fixing them up.
gaw
04-07-2002 19:38:28
Serial number shows that your tractor was made in 1953--making a 44 special.
Bruce Colbourne
04-26-2002 09:56:36
 Re: Re: mh44 or 44sp in reply to gaw, 04-07-2002 19:38:28
The serial number you listed makes you tractor a 1953.The serial numbers for the 44 special starts at 50,001.
