Oil pressure drop MF 35 starts at 50 psi cold and drops to 15 psi when warm?
tortmort
04-07-2002 07:12:33
My MF 35 3 cyl diesel was rebuilt recently and the oil pressure will start off at 50 psi and then after 15 to 20 minutes of use will drop to about 15 psi. Should I be concerned? Thanks
george T
04-18-2002 22:47:14
 Re: Oil pressure drop MF 35 starts at 50 psi cold and drops to 15 psi when warm? in reply to tortmort, 04-07-2002 07:12:33
if it were mine id change the oil firest. my mecanic told me to change the oil at 10 hours and again at 100 hours affter a rebulid it grinds out some metal that will scar the cilender walls and plug the gage good luck george T
Ray
04-09-2002 05:59:20
Don't trust your dash gage,check your oil pressue
at the block.Sometimes those dash gages are not
very accurate.I knew a guy who tore his down
because of low oil pressure,it was just a bad gage.
Big Dean
04-07-2002 21:56:21
I would be concerned if it was mine & it only had 15 psi at operating speed at an idle it would not be quite so bad but still to low
Mike D
04-09-2002 01:41:15
 Re: Re: Oil pressure drop MF 35 starts at 50 psi cold and drops to 15 psi when warm? in reply to Big Dean, 04-07-2002 21:56:21
What weight oil do you use? I have some warm weather, so I use 15-40. Good Luck, Mike D
Jack M, UK
04-08-2002 13:31:33
Isn't that pressure ok, after the oil warms up, it will become more runny (less viscous), so the pressure would drop, RIGHT?
Regards Jack M, UK
lpc
04-08-2002 21:28:26
 Re: Re: Re: Oil pressure drop MF 35 starts at 50 psi cold and drops to 15 psi when warm? in reply to Jack M, UK, 04-08-2002 13:31:33
Yes, but the amount cold and hot is what matters. If that's at idle like someone else mentioned it may be kinda ok. If it's 15 psi at working rpm, that's pretty dang low. Incorrect bearing to crank clearance, bad oil pump or some other loose clearance that won't create enough oil restriction to produce pressure.
Jack M, UK
04-07-2002 09:53:24
Do you know what weight oil is in the engine sump?
