ID
Grant D
04-04-2002 21:13:32
hello,
I'm new to the world of tractors and have recently purchased a massey ferguson which i was led to believe is a MF35, it is a 4 cylinder petrol 4 speed with high and low range, there doesn't seem to be any serial #'s apart from 400207 over 1 rear axle and 400205 over the other. Would any1 be able to give me an idea on id-ing my machine....pls
thx
grant
ALAN
04-05-2002 19:44:14
 Re: ID in reply to Grant D, 04-04-2002 21:13:32
The normal place for a model & s/n tag is up on the dash... It's a 2" x 2" silver colored tag. If that's gone, let's start with the engine size. Below the alternator or generator, just above the "oil pan" is a series of raised letters. 120 = the 20 (you don't have one if you have high low) 129 = 30, 134 = 35,40,50 & prob some others. If it's a 134, the next step would prob be to describe the grill as best possible. Hope this helps - ALAN
C. T. in Oklahoma
04-05-2002 17:29:33
My 1964 35 has 3 speed + reverse with high and low range.
C. T.
Jack M, UK
04-05-2002 04:09:15
I will need someone to verify this, but is it me, or were all 35's 6 speed?
Does it have 2 gear sticks or only 1?
If it only has 1, then I THINK it is probably a Ferguson, not on Massey Ferguson.
Would someone please verify this!
Thanks
Jack M, UK
Roger
04-05-2002 06:14:49
 Re: Re: ID in reply to Jack M, UK, 04-05-2002 04:09:15
My 1957 Ferguson TO-35 has 6 forward speeds, 2
reverse (2 shift levers).
Roger
Jack M, UK
04-06-2002 02:08:39
 Re: Re: Re: ID in reply to Roger, 04-05-2002 06:14:49
ok then, SORRY!
Don't know an owfull lot about TO-30/35's.
Thanks,
Jack M, UK
