Weight of a massey 44
elwood d. large
04-02-2002 20:24:10
i was wondering as i have a chance to purchase one. i need to get it home.also it is $1200 with hydrolics but no 3 point. it does have a wide front and rebuilt motor. is the price write? gas motor. thanks for any info
JDBert
04-03-2002 09:29:06
 Re: weight of a massey 44 in reply to elwood d. largey, 04-02-2002 20:24:10
I have a 49' with nothing but a PTO sticking out the back, it weighs a little under 4000/lbs with pressed steel and 13.6X38's. I'm redoing the motor now, fairly expensive to do, $180 main bearings,$22 per rod bearing, $100 gasket set,ect. I gave $400 for mine Not running(needed a battery, little work) Hope I helped RW
Scrap Iron Man
04-03-2002 07:39:34
Hey, that's cheap, it's only 20 cents per pound ... you can't go wrong for that, especially if the rubber and the rims are decent.
Frank
04-03-2002 06:28:26
Nebraska test results for a 1953 MH 44 Special show a weight of 5789 pounds. The quality of the engine rebuild will affect the cost of keeping it running, as will tire condition, etc. If you really want the tractor, the price is probably OK-- around a thousand dollars, I don't think that market conditions are the determining factor in the price.
