What front loader for MF 40?
Marty Roberts
04-01-2002 22:19:30
I've got a MF 40 (1970) and would like to put a front loader on it. Do you know what loaders will fit this tractor? It has a front pto shaft for the loader hydralic pump.
Curt
04-02-2002 20:16:32
 Re: What front loader for MF 40? in reply to Marty Roberts, 04-01-2002 22:19:30
I have a 73 MF 40 backhoe with a factory MF 32 front loader on it. The hydraulic pump bolts to a cross member under the radiator with two bolts and has a short PTO shaft running to it from the vibration dampner on the crank. MF industrial application for the MF 40 and MF 32 loader can give you the pump number/type/capacity. An aftermarket will work on it but the specs/mounting configuration/and pto sleeve size need to be known to match the splined shaft that runs the pump.
Lloyd
04-02-2002 09:50:29
I have a MF40 and it has a M34 loader on it.
tim wi
04-02-2002 03:51:40
mod 30 33 mf loaders my 74 40ind has a mod 30
Marty
04-02-2002 09:34:34
 Re: Re: What front loader for MF 40? in reply to tim wi, 04-02-2002 03:51:40
Is there a universal or aftermarket hydralic pump that fits the front of the MF 40 to run the front loader?
