M-F 135 governor
steve
03-29-2002 22:55:01
This motor is hard to keep at a sertain idle speed if you try to set it at 1000 rpm it jumps to 1800 and if I try to reduce the rpm's bien slow and carefull it some time go's all the way to 600 . I think it might be the governor or could it be something other!! .
BHO
03-01-2003 05:27:07
 Re: M-F 135 governor in reply to steve, 03-29-2002 22:55:01
steve, I have the same problem. A mechanic
freind (BMW) thought it might be the slop in the carberator. That seems reasonable in that air flow would be willy-nilly. Let me know if you found anything different. This tractor also pulls a 200 gallon sprayer(organic) and the rpm goes up and down depending on the load. I wind up holding the throttle trying to keep it even. I actully need a third hand. I did replace the fibre washer in the linkage and that did not help.
