M-F 135 PTO problems
Steve
03-29-2002 22:38:11
This tractors as independent pto it keeps turning slow all the time and when I engage it there is no change I can stop the shaft by grabbing it. Could the clutch be slipping this bad or did something else give out any help is welcom .thanks
david
04-08-2002 19:45:28
 Re: M-F 135 PTO problems in reply to Steve, 03-29-2002 22:38:11
yes the clutch can be that far gone, the center of the disc can be broken out, or the splines on the collar that engages the clutch can stripped. I've seen tractors bought a auctions that had a broken pto shaft that were patched together with a piece of rubber hose and two hose clamps. It looks good at the auction but when you use it ,you'll find it. Good luck.
