MF35-Trans.+Rearend Capacity?
Joe
03-28-2002 14:53:21
How much oil does the MF35 common sump hold? Thanks for the info.!
Thyge
03-29-2002 01:21:02
 Re: MF35-Trans.+Rearend Capacity? in reply to Joe, 03-28-2002 14:53:21
My manual says: Transmission and rear end:
30 litres straight mineral oil SAE40.
Changing interval 750hrs. More often when using a loader (manual then suggests every 250-500 hrs depending on the degree of loader use).
At the same time check the filter. Big Dean has info on doing this, and be sure to use safety wire, or your wallet will be sorry.
Thyge
Taageskov Denmark
Joe
03-29-2002 17:40:22
 Re: Re: MF35-Trans.+Rearend Capacity? in reply to Thyge, 03-29-2002 01:21:02
Hey Thyge, Thanks for the reply. I wonder if the overseas model is the same as U.S.? If I remember right (been a long time since school!)there are a little over 4 liters in a gal.,right? Thanks again! Joe
Roger
04-01-2002 06:29:18
 Re: Re: Re: MF35-Trans.+Rearend Capacity? in reply to Joe, 03-29-2002 17:40:22
Joe; 3.785 liters = 1 gallon
Chris C.
03-28-2002 19:55:18
Right at 8 gallons, be sure you use the older style "mineral " fluid.
Joe
03-28-2002 20:35:40
 Re: Re: MF35-Trans.+Rearend Capacity? in reply to Chris C., 03-28-2002 19:55:18
Thanks for the reply Chris. Just got it last fall and trying to do some maintance before the weather breaks. Did'nt want to little or to much! Thanks again!
