MH 30 Negative ground and starter
Tom S.
03-28-2002 10:38:36
How do convert to a negative ground system and still have the starter turn in the correct direction?
Alberta Mike
03-28-2002 14:53:00
 Re: MH 30 Negative ground and starter in reply to Tom S., 03-28-2002 10:38:36
The starter is a very insensitive creature, it won't care whether it is supplied with 6 or 12 volts, nor does it make any difference if the voltage is given as positive or negative ground, it will spin the same way. Good thing too because if it spun backwards, then the starter Bendix drive wouldn't work.
