Steering problem for Massy Ferguson 35
Stuart Lightbur
03-27-2002 12:19:55
Need advice on how to fix steering on Massey Ferguson 35. It just quit. Is it a pin out or a bearing maybe? Any info would be greatly appreciated.
Thyge
03-29-2002 01:46:04
 Re: Steering problem for Massy Ferguson 35 in reply to Stuart Lightburn, 03-27-2002 12:19:55
A little more info would be nice...
Is it power assisted or manual?
Does the steering wheel just turn freely?
The manual steering unit is of the "recirculatory ball nut type" and if more than a few of the balls have "left the circuit" you will have absolutely no steering function. I had one of my '35's doing that due to a loose steering shaft. (the outer tubing had about half an inch end play at the steering box)
I believe you will have to look inside to see what is your actual problem. Otherwise it is no problem to retrieve a replacement unit from a salvage carcass (at least not here in DK)
Good luck
Thyge
Taageskov
Denmark
