Clutch on super 90
Terry
03-25-2002 17:52:17
Need to know how to adjust clutch on super 90 propne tractor
winston
04-01-2002 19:36:41
 Re: clutch on super 90 in reply to Terry, 03-25-2002 17:52:17
terry, i happen to have the same tractor and a repair manual. You really need a extra hand to do this job. There is also an adjustment for the transmision shaft break. I would be happy to help you with that if you like.
to adjust clutch 1)loosen clamp bolts on pedal. 2)rotate clutch shaft clockwise untill contact (throw out bearing comes against clutch relese fingers) 3) position pedal with 3/8" clearnce from upper stop. 4) tighten clamp bolts 5)recheck pedal freeplay 3/8"
good luck, winston
