Trans. wont hold
Murrel
03-24-2002 03:38:09
Hi Folks Need to ask a favor,I just bought a M.F. 165 from a dealer . my problem is when I shut the engine off the tractor starts to roll no matter which gear the trans is in . I have to lock the brakes to park the tractor,is this normal,it is diesel with multi power which all seems to work fine , sure would appreciate any information you can give me. Thanks in advance
Fish
03-26-2002 08:09:47
 Re: trans. wont hold in reply to Murrel, 03-24-2002 03:38:09
The trans. should hold if Multi-Power is shifted into high range before shuting the tractor off.
henning thomssen
03-24-2002 08:47:41
That's normal with a Multipower,as you probably know,there is no engine-braking in low range,it has to do with how the freewheeling mechanism works,big dean's website explains it real good,when you shut the tractor off,just put it in reverse when it is facing downhill,or in first when facing uphill.Thats what I do with my MF50
John
03-24-2002 08:42:43
Thats normal for the multi power trans. You will have to lock the brakes when the engine is not running. Also you cannot tow the multi power tractors to start them.
