Fuel in the oil?
JR in AR
03-23-2002 20:38:31
I have a MR 165. I changed oil last year before using it. When I checked after setting all winter it was about 3 qts. over full. My question, is it possible for fuel to have gotten into the oil while setting all winter? It is a diesel.
Thyge
03-24-2002 15:03:27
 Re: Fuel in the oil? in reply to JR in AR, 03-23-2002 20:38:31
btw.. are you sure that it is fuel in the oil and not half a gallon of water in the sump?
(check for milky oil and "mayonnaise")
Thyge
03-24-2002 14:59:17
Yes, through the front seal of the fuel pump or a leaking diaphragm in the hand/pre pump.
You can find out by looking for air in the system after running the engine with the shut-off valve closed. If you get air in the filter/glass, it is most likely a pre-pump leak. If not, it gets a little more expensive....
Thyge
Taageskov
Denmark
