Is this Massey 35 worth it?
Jason
03-20-2002 15:34:22
I found a Massey FE35 with a Standard 23C diesel engine. I haven't seen the tractor yet, but the guy tells me that it has 0 hours on complete engine overhaul and new paint. From what I hear, the 3 cyl. diesel is the better one, but they are very hard to find. Is there such thing as a Standard 23C diesel? What should I offer for a price? From Canada.
henning thomssen
03-20-2002 17:38:43
 Re: Is this Massey 35 worth it? in reply to Jason, 03-20-2002 15:34:22
Yes,there is a Standard Diesel in the 35's,they were not a terribly bad engine,they were just much harder to start than the perkins.they use four glowplugs,and it needs them to get going.If one fails,none of them work,to replace one costs around $60cdn,if i remember correctly,this was 5 years or so ago.As for value,it seems this engine is around cdn$1500-2000 less than a perkins in similar shape.A perkins isn't all that hard to find.
Jack in NB
03-22-2002 03:42:45
 Re: Re: Is this Massey 35 worth it? in reply to henning thomssen, 03-20-2002 17:38:43
The Standard is a good, reliable engine. A bit less power than the Perkins 3 cyl, but lots of lugging power. Ours had probably 5000 hours when I overhauled, and the crank was still standard size.
The hard starting can be cured with a 200-300 watt block heater in the lower rad hose. 15 min in summer, an hour in winter.
If it starts at zero c now, it's ok.
We sold ours a year ago for $3400. Replaced it with a 135 w/loader which needed a major overhaul, for $2000. (Overhaul cost $1500 parts and machine shop - did most of the work ourselves.)
The 35 is one of the best tractors in its size ever built. The Perkins 3 cyl is the best engine in them. Overhaul kit is half to 2/3 the cost of most others - probably because there are so many around.
Might be worth waiting for one of them.
Enjoy - whichever way you go!
Jack in Fredericton NB
