M-h 44 governor adjustment
Farm Man
03-20-2002 10:17:39
I cant seem to get the gov. adjusted right. If i adjust the carb. to not run too rich the gov. surges like crazy. I know the throttle linkage is not original on this tractor, so I cant go by the book. Can anyone tell me how to set it by "feel" or "eye"?
wayne
03-22-2002 11:23:20
 Re: m-h 44 governor adjustment in reply to Farm Man, 03-20-2002 10:17:39
on the front cover of the engine,on the left side there is a screw with a lock nut on it.Loosen the locknut take the throttle up till the engine starts to hunt,turn the buffer screw in and see if it stops hunting.
good luck
Wayne
Val
03-21-2002 10:38:58
I had that problem on my 44 std. Finally swapped the governor with my 44 RC and the problem went with the governor. Governor shaft and weight pins were worn badly. Tractor pulled ok under load but otherwise gallopped. May be your problem too.
