MH 44D Special sparkplug
Will-Texas
03-15-2002 10:05:06
Just got in a 44D Special and am wondering just how the sparkplug in the intake works. I am assuming that gasoline was supplied to the manifold and was fired by the plug to warm things up for starting, but the line just stops...I'm thinking a tank has been removed just in front of the main fuel tank as an extra battery is in this location now. Anyone familiar with this setup?
David B
03-15-2002 17:20:27
 Re: MH 44D Special sparkplug in reply to Will-Texas, 03-15-2002 10:05:06
It is a spark plug and burns fuel from the main fuel tank. The line going to the bottom of the manifold should be connected to a primer pump that is mounted thrugh the dash below the gaughes. This hooks into the fuel system at a valve just below the final filter. My tractor has this starting aid but I never tried to use it. The second battery under the hood ahead of the fuel tank is normal for a diesel.
marlowe
03-15-2002 16:49:27
i think you have a glow plug not a spark plug a glow plug is used to warm the air in the intake manafold to help with starting in the cold there is no gas used. the glow plug is heated with the switch turned and held for 10 to 20 sec.then push starter button
