Adding hydraulics
lpc
03-13-2002 22:42:47
I've been looking at what MF go for in the local ag paper along with doing searches on the net. Have found that combining price, features, size and preference, something along the lines of a 150, 165, or maybe a 250 looks pretty good, if the funds match the wants. Most all of the ones that are cheap enough seem to be missing hydraulics. Are there some of these models that when adding to are pretty simple, and some better not attempted? Trying to stay in the $2500-$5000 range.
Willy
03-14-2002 16:53:29
 Re: Adding hydraulics in reply to lpc, 03-13-2002 22:42:47
If you are refering to remote hydraulics on the massey tractors there is a switch valve that replaces the small rectangular plate under your right knee that you can get from your massey dealer for less than $100.00 then depending on if you need single or double acting cylinders you can get hoses and control valve from a farm store (tsc) to set up the connectors for remote hyds whole set up probably less than $400-$500 hope this helps if you need more info just post again have a good one Willy
lpc
03-14-2002 21:22:55
 Re: Re: Adding hydraulics in reply to Willy, 03-14-2002 16:53:29
Is it this simple on virtually all MF's or just a few models? How old(cheap) can I go on a tractor and still add the hydraulics this easy?
BlueLite
03-14-2002 04:58:38
If your looking at later models, I'd be surprised they don't already have hydraulics.
I'm not familiar with the later models. If your working just a few acres, you can go from 30Hp
on up for your needs. By the time the Ferguson interests came into
the business, most tractors had hydraulics. I'm pretty sure that by the time Harris bowed out, they had hydraulics. My MasseyHarris 30 didn't and it's what's called a puller, does odd jobs around the farm back then. Then MH saw what was happening and offered an add on hydraulic system that any dealer could
put on. That's what I have and I put it on myself. A pump that fits on the timing gear, a 2 way cylinder with control lever under the seat, a oil reservoir that sits in front of the rad, plus the lines, and a lift mechanism that's all there is.
