What is MF 135 HP?
Jack M, UK
03-12-2002 13:19:44
What is the rated HP for a 3 cylinder 135?
Jack Fowler
03-16-2002 21:01:55
 Re: What is MF 135 HP? in reply to Jack M, UK, 03-12-2002 13:19:44
third party image
H.P. & Specs For a Perkins Three Cylinder
Big Jim
03-12-2002 14:42:45
Is this a gas or diesel engine? according to my book they made a 3cyl. Perkins diesel engine and also a 3cyl. Perkins gas engine for the same tractor. The diesel engine is rated at 37.8 PTO HP and 33.6 drawbar HP. The gas engine is rated at 37.5 PTO HP and 32.4 drawbar HP.
bill
03-14-2002 06:33:40
 Re: Re: What is MF 135 HP? in reply to Big Jim, 03-12-2002 14:42:45
According to what I've heard the MF 135 diesel has 47 hp. That is what the manufacturer announced. I assume that your number were taken from the Nebraska test results. It seems that these results are not correct sometimes. There was a thread in the Fordson forum a little while ago and it came to same conclusion. Maybe the numbers were made to look bad in comparison to American tractors.
Jack M, UK
03-13-2002 06:15:20
It is a diesel.
Don
03-12-2002 19:28:24
Dont forget the continental 4 cyl.
there are 3 or 4 different engines used in the 135. 3 in the 135 deluxe and 1 in the regular 135. I'm not sure of the difference.
Jack Fowler
03-14-2002 14:35:25
 Re: Re: Re: What is MF 135 HP? in reply to Don, 03-12-2002 19:28:24
Gas & Diesel (3cyl. Perkins) are the same flywheel H.P. (42) and drawbar H.P (33) If you want specs out of the factory service manual I'll post or send them to you . Jack
Jack M, UK
03-16-2002 15:21:26
 Re: Re: Re: Re: What is MF 135 HP? in reply to Jack Fowler, 03-14-2002 14:35:25
I'd love those specs please!
Also do you have the engine head tigtening torques, need them to get a tight gasket seal.
Thanks alot
Jack M, UK
Jack Fowler
03-16-2002 20:44:22
 Re: Re: Re: Re: Re: What is MF 135 HP? in reply to Jack M, UK, 03-16-2002 15:21:26
third party image
For Jack M. AD 153 Perkins Headbolts
