TractorMeter
Jeff
03-11-2002 17:33:52
I am working on a recently purchased MF50. It did not have the flex-shaft drive cable that goes between the TractorMeter (RPM and Hourmeter) and the generator. I bought one and installed it. My problem is that the Tractormeter is turning backwards.
Any suggestions or advice would be greatly appreciated.
Thansks..
Larry from NY
03-12-2002 07:20:01
 Re: TractorMeter in reply to Jeff, 03-11-2002 17:33:52
Jeff,
I think that this may be your problem. The 50, as well as the 35 have tractormeters that run clockwise. The 135 series runs counterclockwise. For about $65 you an get a new tractormeter for the 135 with the appropriate mph bands, but the original clockwise tratormeters are few and far between. I'll bet that someone replaced your original tractormeter with a new one. When it didn't work, he just disconnected it and left it for you.
What direction is your tractormeter?
Jeff
03-12-2002 17:33:29
 Re: Re: TractorMeter in reply to Larry from NY, 03-12-2002 07:20:01
Someone apparently HAS swapped the Tractormeter out on this unit. Since I am planning on using it for work instead of restoration, I purchased a newer model tach from the M/F dealer. It is a tach and hourmeter, but does not have the bands that indicate speed. No biggie though.
Thanks.
Jeff
