FE-35 Aligning front wheels
Craig in NZ
03-11-2002 16:42:36
Hi team,
The front wheels of my FE35 4cyl diesel are not exactly aligned - I mean while one points straight ahead the other points slightly off to one side. I'm sure this is not helping my turning ability!. Is there some adjustment I can use to get them both heading in the same direction?. Thanks in advance.
Craig
Roger
03-11-2002 17:32:40
 Re: FE-35 Aligning front wheels in reply to Craig in NZ, 03-11-2002 16:42:36
Craig;
My MF service doesn't get into how to get the wheels parallel, but it does specify a toe-in setting of 0 to 1/4". Here's how I did this on my TO-35: I attached two 6' levels one to each front wheel/tire with bungee cords. These served as straight edges from which I adjusted each wheel until they were parallel to one another and then adjusted each wheel slightly until the distance in the front end of the levels was 1/4" less that that of the rear end of the levels. The adjustments are made by loosening the nuts at each end of the drag links and turning the tube in or out to lengthen or shorten the drag link. I wasn't able to come up with a way to ensure that while the wheels were parallel to each other, they were also pointing exactly forward. I eye-balled that one...
Hope this helps.
Roger
