Sterring on a MH33
matt
03-07-2002 10:22:07
i just bought a MH 33. the sterring has a lot of play in the sterring box before it turns the wheels. does anyone know how to fix this.
BlueLite
03-18-2002 09:52:50
 Re: sterring on a MH33 in reply to matt, 03-07-2002 10:22:07
Sorry to catch your post late.
I think your box is the same as my MH30.
You have to make sure the front wheels are facing forward and center. Locate the lash adjuster plate on the steering box. It has a circular slot with a bolt holding it down. The plate will have a cutout arrow on it. Loosen the bolt about 1/2 turn. With a light hammer tap on the adjuster on the flat part of the adjuster just behind the arrow to turn it in the direction of the arrow. Move only 1/16in at a time. Do not tighten too much as damage can result. Preferably 1-1/2 to 2-1/2lbs of pull should turn the steering gears when measured on the rim of the steering wheel.
matt
03-19-2002 21:10:25
 Re: Re: sterring on a MH33 in reply to BlueLite, 03-18-2002 09:52:50
thats for the tip blue, i will try that and see if it will work.
