MF65 Head/Manifold Fit-up
Ken Brading
03-05-2002 14:30:46
I have a gasoline MF65 with the Continential G176 engine. I'm puzzled about the fit-up of the manifold assembly to the head. The head doesn't have a stud to hold down the adjacent edges of the exhaust flanges between cylinders #2 and #3. My parts manual shows this to be the correct configuration yet my aftermarket manifold and gasket are drilled/punched for a stud there. I don't believe there was a leak there before I took it apart, but I wasn't paying that close of attention. Does anyone know if this arrangement is prone to leaking? Is there an common treatment for this problem that everyone but me knows about? Close examination of the head looks like tapping a hole in that location would only intersect a head bolt passage. Has anyone done that?
Ken Brading
David B
03-06-2002 09:28:53
 Re: MF65 Head/Manifold Fit-up in reply to Ken Brading, 03-05-2002 14:30:46
My 65 has a cast short bar that goes across the manifold ears and over the stud. This stud then holds down the manifold on both sides of the stud.
David B
Ken Brading
03-06-2002 10:10:51
 Re: Re: MF65 Head/Manifold Fit-up in reply to David B, 03-06-2002 09:28:53
So then has your head has been drilled and tapped for a stud between exhaust ports #2 and #3 and it's a Continential G176 gasoline engine?
Ken
