Massy Ferguson 35
V
03-03-2002 14:35:08
Has anyone heard of a Massy Ferguson 35 "Deluxe" ? If so, what is the difference. Thanks.....
brian keefer
10-06-2003 18:00:44
 Re: Massy Ferguson 35 in reply to V, 03-03-2002 14:35:08
iam looking for leveling adgustment rod and crank for 3 point hitch
BYRON
07-29-2003 17:05:18
I THINK I HAVE A DELUXE. 1963 MF-35. TACH, AMP , OIL PRESSURE , GAS , WATER TEMP METERS, GROUND AND ENG PTO, TWO STAGE CLUTCH, SPIN OUT WHEELS, LIGHTS FRONT AND REAR, TOOL BOX IN FENDER, MULTI-POWER, AND A GAS ENGINE. BUT IT DOES NOT HAVE ANY MARKINGS OF "DELUXE" DO THE OPTIONS ABOVE MAKE IT A "DELUXE"??
I HAD BEEN LOOKING TO BUY AN 8N WHEN I FOUND THIS TRACTOR. IT WAS FOR SALE FOR A YEAR AND NOBODY EVER BOUGHT IT. IT LOOKS IN GREAT SHAPE AND RUNS EVEN BETTER. I AM GLAD I BOUGHT IT AND NOT THE FORD!!
Roger
03-06-2002 10:11:04
This from an MF owner's manual (no date, just #690
241 m4): The Deluxe included as standard:
Dual Clutch; Ground Speed PTO; Tractormeter;
Foam Float Seat. Offered as optional equipment
were Power Steering; "Hi-Altitude" engine (8.10:1
comp ratio); wide selection of tires on either
standard wheels or power adjusted wheels.
While there's no mention of it in the this portion
of the book, mine has a 4 guage dash (oil, temp,
amps, tractormeter). Also, mine does NOT have the
dual clutch but does have the three position PTO
shift lever (engine PTO, ground PTO, neutral).
All things considered, looks like the "Deluxe"
came in many different flavors.
Roger
jim
03-04-2002 08:15:37
I believe a 35 Deluxe also had power steering either standard or as an option.
C. T. in Oklahomo
03-03-2002 20:26:35
I have a 35 deluxe, what are spinout rear wheels?
Thanks,
C. T.
Magnum65
03-04-2002 08:35:15
 Re: Re: Massy Ferguson 35 in reply to C. T. in Oklahomo, 03-03-2002 20:26:35
Spinout rear wheels allow you to position the tires wider for a safer stance in hilly terrain. We owned a 1961 35 Deluxe for 27 years. Good tractors. Good luck.
Yankee
03-03-2002 18:35:03
The deluxe model came with many items not available on the other models.Including larger tires front and rear with spin out rear wheels,a ground speed pto in addition to the live pto W/dual stage clutch,lights,A tractormeter,fuel gauge,ammeter,temperature gauge,a much more comfy seat,and a quick-adjustable upper link.My first tractor is a MF35Deluxe,just got lucky.It's a great tractor.
Roger
03-04-2002 07:23:21
 Re: Re: Massy Ferguson 35 in reply to Yankee, 03-03-2002 18:35:03
Yours has a fuel guage?
Yankee
03-08-2002 20:03:36
 Re: Re: Re: Massy Ferguson 35 in reply to Roger, 03-04-2002 07:23:21
Yea it's got the fuel gauge but it isn't real accurate.I need to adjust the float.Mine is a 1964 model,maybe the year is the difference.
Tom
03-11-2002 21:01:08
 Re: Re: Re: Re: Massy Ferguson 35 in reply to Yankee, 03-08-2002 20:03:36
I have a 1961 35 Deluxe. It has a fuel gauge.
Chris C.
03-03-2002 17:11:43
Spin out wheels, Foam Float seat and dual stage clutch as a package. Although you could get all these option seperately. The diesel came with the dual clutch and foam float seat.
MODERN IRRIGATION CO
05-18-2002 07:45:18
 Re: Re: Massy Ferguson 35 in reply to Chris C., 03-03-2002 17:11:43
Dear sir,
SALES DEPT.
We are looking for the following machines purchase:
- A potato planter(seeder).
- A furrow maker machine.
- potato earthing up machine.
- A potato harvester.
Which tractor can fit to operate all the above.
We look forward to hearing from you soon.
Thanks & Best regards,
Eng.Mohd al-Jayyousi
Sales Manager.
Hal
03-04-2002 18:31:55
I have a TO-35 Deluxe bought new. It has 2-stage clutch and ground speed PTO, nothing else differnet. Maybe more options were made available in later years.
V
03-04-2002 13:31:42
We bought the tractor new in '59. It's been a great tractor! It has a two stage clutch, gasoline engine, no fuel gauge, and no power steering, yet is says 35 deluxe.
