Massey Harris 44 serial number question
Strass
02-27-2002 17:23:44
I am new to the massey tractor and I have one that says 44G1RF and then the number I found the year which it was. My question is how do you know if you hace a 44 special. I know this may sound dumb but I am curios. Thanks for any help
Bruce Colbourne
02-28-2002 19:36:13
 Re: Massey Harris 44 serial number question in reply to Strass, 02-27-2002 17:23:44
The 44special has a longer front frame and the engine is a 277 cubic inchs.The front hubs are also different. The front wheels are held on with lugs and nuts rather than just wheel bolts.The front pedastal is also built heavier it has aextra bracket on the back side of the axle.
David b
03-04-2002 15:43:21
 Re: Re: Massey Harris 44 serial number question in reply to Bruce Colbourne, 02-28-2002 19:36:13
The frames on my 44 and my 44 Special measure the same in length.
Tom
03-03-2002 21:58:54
Bruce, I don't know what you got there but the frame on a 44 and 44 Special, measure approximately 69 1/2 inches long. The Special frame has a thicker side rail of 1 inch compared to a 44 which is 3/4. The front ends are taller but I've never seen an extra bracket.
David B
02-27-2002 20:31:11
The model numbers apply to the 44's and 44 Special alike. Only the serial numbers identify the different years.. 44's ended in 1953 with 47,060. The Specials start 1953 50,001 to 51,363 1954 51,364 to 58,066 and 1955 58,067 to 60,719
David B
02-27-2002 20:24:14
What you have listed is the model for a 44 G-gas, 1-reg altidude, R-rowcrop, F-foot clutch. This applys to the Special as well as reg 44. The serial numbers for 44 Specials start at 50,001.
44 Special 1953 50,001-51,363 1954 51,364-58,066 1955 58,067-60,179
David B
02-27-2002 20:20:57
David B
02-27-2002 20:18:26
